YUKON GEAR & AXLE - AXLE SHAFTS Yukon Gears alloy steel axle shafts feature rolled splines instead of weaker cut splines, which makes them a perfect upgrade from factory and most aftermarket shafts that wear out as much as 30 percent faster and theyre actually cheaper than most replacement axle shafts. Yukon Gear was founded in Washington state where extreme weather and off-roading are commonplace and manufactures performance products that were built to perform and built to last in harsh environments.Custom fit by vehicle year/make/modelSold as an individual pieceState-of-the-art rolled spline technology gives axles 30% more strength than cut splinesPremium grade replacement for old or worn out shaft and costs lessConstructed of premium-grade alloyAdded compound around yoke means added strengthBacked by a 5-year warranty
