For customized styling, dress-up your vehicle's interior with Garage Seat! This premium-grade seat is built with all-steel frame with molded foam padding that uses spring suspension for comfortable ride. It features a folding-seat design that gives your vehicle a smooth, sleek appearance. The seat is upholstered using premium quality vinyl.Made from high quality materialsAffordable solution for your restoration needsComes with 1-year Garage Pro limited warrantyGo pro with Garage Pro! Garage Pro products are unequaled in quality, durability and value - you and your car will be spoiled from your first purchase to your last.
