DAYCO TIMING BELT -- 65.20 in. effective length, 1.26 in. top width, 207 teeth; For water pump driven by timing belt; Features patented and self-lubricating fabric that provides exceptional resistance to abrasion for extended pulley and belt life; Its molded cog design runs quieter and is more economical than chain drives; Designed with a high modulus glass fiber non-stretch cord that delivers precise length stability to keep the engine running smoothly over the life of the belt; The belt's compounding and tooth configurations are designed for specific applications ranging from normal service to high performance and high temperature engines; Meets all OEM specifications.
