ZARA (R) Ultra Max Interior Wood Stains feature Core/Shell Drying Technology for the deep tones of an oil-based stain with the low odor, fast drying and easy clean-up of a water-based stain. The Advanced Green Phase Resin Dispersion utilizes environmentally friendly resins that result in a VOC compliant family of stains. They wipe on like furniture polish, and feature controlled penetration for rich, even tone. Applied with a soft cloth, there is no risk of lap marks or streaking. They can be applied to all varieties of unfinished wood and to many types of previously finished, painted or varnished surfaces to achieve a wood grain effect. Try using the stains with the ZAR Wood Graining Tool (#50397, sold separately) to make fiberglass, steel or composite doors look like wood. Will not adhere to shellac or lacquer-these should be removed before staining.Features: Top coat with any formula of ZARA (R) polyurethane for lasting beauty and protectionIdeal for furniture, hardwood floors, woodwork and wood, metal or fiberglass doorsNo conditioner neededVOC compliantTintable
